yashael
4 years agoStratix 10 PAC HSSI example
I'm trying to understand how to use the hssi interface in stratix 10 PAC. I had some problem on rx_data_valid (PCS Direct on serial loopback) But unable to reproduce the issue, so i'm creating a ...
JohnT_Altera
4 years agoHi,
From your pattern_gen.v, I observed that there is additional port for valid. May I know how do you connect the valid signal? Are you able to share with me the full design?
- yashael4 years ago
Yes i have that additional port, however i didn't use it yet to keep it the same with the original pattern_gen.v
the prbs_top look like this.// `include "pr_hssi_if.vh" module prbs_top #( parameter NUM_HSSI_RAW_PR_IFCS = 2, parameter NUM_HSSI_LN = 4, parameter PRBS_DATA_WIDTH = 8, parameter PRBS_INITIAL_VALUE = 97, parameter PRBS_TAP = 31, parameter PRBS_XAUI_PATTERN = 97, parameter PRBS_NUM_CYCLES_FOR_LOCK = 8'd31, parameter PRBS_PIPELINE = 3 ) ( input logic clk, // Primary CCI-P interface clock. input logic clk_125, input logic softReset, // Raw HSSI interface pr_hssi_if.to_fiu hssi [NUM_HSSI_RAW_PR_IFCS], // HSSI control signals input logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0] rx_seriallpbken, // PRBS control signals input logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0] prbs_insert_error, input logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0] prbs_pause_tx, input logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0] prbs_pause_rx, // PRBS status signals output logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0] prbs_lock, // HSSI feedback signals output logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0] tx_ready, output logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0] rx_ready, // PRBS counters output logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0][31:0] prbs_tx_count, output logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0][31:0] prbs_tx_err_count, output logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0][31:0] prbs_rx_count, output logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0][31:0] prbs_rx_err_count, // Resets input logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0] cr2hssi_reset, input logic [NUM_HSSI_RAW_PR_IFCS-1:0][NUM_HSSI_LN-1:0] cr2ctr_reset, output logic [PRBS_DATA_WIDTH-1:0] rx_prbs_02, output logic [PRBS_DATA_WIDTH-1:0] tx_prbs_02 ); // logic to stage sync for output logic [31:0] prbs_tx_count_d [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_tx_count_en [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic [31:0] prbs_rx_count_d [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_rx_count_en [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic [31:0] prbs_tx_err_count_d [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_tx_err_count_en [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic [31:0] prbs_rx_err_count_d [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_rx_err_count_en [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; // logic operating on hssi if clocks logic [31:0] prbs_tx_count_hssi [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic [31:0] prbs_rx_count_hssi [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic [31:0] prbs_tx_err_count_hssi [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic [31:0] prbs_rx_err_count_hssi [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_pause_hssi_tx [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_pause_hssi_rx [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_gen_data_valid [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_pause_gen [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_pause_chk [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_pause_chk_sync [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_insert_error_hssi [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_insert_error_hssi_q [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_insert_error_hssi_e [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_lock_hssi_rx [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_lock_hssi_rx_sync [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic shift_lock_hssi_rx [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic shift_lock_hssi_tx [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_seriallpbken_hssi [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic hssi_reset [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; // PRBS outputs logic [PRBS_DATA_WIDTH-1:0] prbs_dout [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic [PRBS_DATA_WIDTH-1:0] shift_dout [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic [PRBS_DATA_WIDTH-1:0] prbs_din [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic [PRBS_DATA_WIDTH-1:0] prbs_din_sync [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_error_flag [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic prbs_error_flag_sync [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; //TX XCVR Clock Shared for 4 channels per QSFP logic tx_clk [NUM_HSSI_RAW_PR_IFCS]; logic tx_arst_n [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic tx_arst_n_d [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; //RX_CLKOUT 4 independent clocks per QSFP logic rx_clk [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_arst_n [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_arst_n_d [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic plls_locked [NUM_HSSI_RAW_PR_IFCS]; logic rx_data_valid [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic cr2hssi_reset_sync [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic cr2ctr_tx_reset_n [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic cr2ctr_rx_reset_n [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic tx_count_reset_n [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_count_reset_n [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic hssi_ch_reset [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic pll_arst_n [NUM_HSSI_RAW_PR_IFCS]; logic tx_analogreset [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic tx_digitalreset [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_analogreset [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_digitalreset [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_analogreset_stat [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_digitalreset_stat [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic tx_analogreset_stat [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic tx_digitalreset_stat [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_is_lockedtodata [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic tx_cal_busy [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; logic rx_cal_busy [NUM_HSSI_RAW_PR_IFCS][NUM_HSSI_LN]; genvar ch_idx, if_idx; generate for (if_idx = 0; if_idx < NUM_HSSI_RAW_PR_IFCS; if_idx = if_idx + 1) begin : HSSI_IF assign tx_clk[if_idx] = hssi[if_idx].f2a_tx_parallel_clk_x2; assign plls_locked[if_idx] = hssi[if_idx].f2a_atxpll_locked & hssi[if_idx].f2a_fpll_locked; resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_async_reset ( .clk (clk_125), .reset (~plls_locked[if_idx]), .d (1'b1), .q (pll_arst_n[if_idx]) ); for (ch_idx = 0; ch_idx < 4; ch_idx = ch_idx + 1) begin : HSSI_CH resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_tx_ctr_reset_sync ( .clk (tx_clk[if_idx]), .reset (cr2ctr_reset [if_idx][ch_idx]), .d (1'b1), .q (cr2ctr_tx_reset_n [if_idx][ch_idx]) ); resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_rx_ctr_reset_sync ( .clk (rx_clk[if_idx][ch_idx]), .reset (cr2ctr_reset [if_idx][ch_idx]), .d (1'b1), .q (cr2ctr_rx_reset_n [if_idx][ch_idx]) ); resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_prbs_pause_tx_sync ( .clk (tx_clk[if_idx]), .reset (1'b0), .d (prbs_pause_tx [if_idx][ch_idx]), .q (prbs_pause_hssi_tx [if_idx][ch_idx]) ); resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_prbs_pause_rx_sync ( .clk (rx_clk[if_idx][ch_idx]), .reset (1'b0), .d (prbs_pause_rx [if_idx][ch_idx]), .q (prbs_pause_hssi_rx [if_idx][ch_idx]) ); resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_prbs_ins_err_sync ( .clk (tx_clk[if_idx]), .reset (1'b0), .d (prbs_insert_error [if_idx][ch_idx]), .q (prbs_insert_error_hssi [if_idx][ch_idx]) ); resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_prbs_lock_sync ( .clk (clk), .reset (1'b0), .d (prbs_lock_hssi_rx [if_idx][ch_idx]), .q (prbs_lock [if_idx][ch_idx]) ); resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_shift_lock_sync ( .clk (tx_clk[if_idx]), .reset (1'b0), .d (shift_lock_hssi_rx [if_idx][ch_idx]), .q (shift_lock_hssi_tx [if_idx][ch_idx]) ); // reset signal outputs assign hssi[if_idx].a2f_tx_analogreset [ch_idx] = tx_analogreset [if_idx][ch_idx]; assign hssi[if_idx].a2f_tx_digitalreset [ch_idx] = tx_digitalreset [if_idx][ch_idx]; assign hssi[if_idx].a2f_rx_analogreset [ch_idx] = rx_analogreset [if_idx][ch_idx]; assign hssi[if_idx].a2f_rx_digitalreset [ch_idx] = rx_digitalreset [if_idx][ch_idx]; // reset status inputs assign rx_analogreset_stat [if_idx][ch_idx] = hssi[if_idx].f2a_rx_analogreset_stat [ch_idx]; assign rx_digitalreset_stat [if_idx][ch_idx] = hssi[if_idx].f2a_rx_digitalreset_stat [ch_idx]; assign tx_analogreset_stat [if_idx][ch_idx] = hssi[if_idx].f2a_tx_analogreset_stat [ch_idx]; assign tx_digitalreset_stat [if_idx][ch_idx] = hssi[if_idx].f2a_tx_digitalreset_stat [ch_idx]; assign rx_is_lockedtodata [if_idx][ch_idx] = hssi[if_idx].f2a_rx_is_lockedtodata [ch_idx]; assign tx_cal_busy [if_idx][ch_idx] = hssi[if_idx].f2a_tx_cal_busy [ch_idx]; assign rx_cal_busy [if_idx][ch_idx] = hssi[if_idx].f2a_rx_cal_busy [ch_idx]; resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_async100_reset ( .clk (clk_125), .reset (1'b0), .d (cr2hssi_reset[if_idx][ch_idx]), .q (cr2hssi_reset_sync[if_idx][ch_idx]) ); assign hssi_ch_reset[if_idx][ch_idx] = !pll_arst_n[if_idx] | cr2hssi_reset_sync[if_idx][ch_idx]; reset_controller inst_reset_controller ( .clock (clk_125), .reset (hssi_ch_reset[if_idx][ch_idx]), .tx_ready (tx_ready[if_idx][ch_idx]), // out to FME and to PR boundary .rx_ready (rx_ready[if_idx][ch_idx]), // out to FME and to PR boundary .pll_locked (plls_locked[if_idx]), // both ATX and fPLL are locked .pll_select (1'b0), .tx_analogreset (tx_analogreset [if_idx][ch_idx]), .tx_digitalreset (tx_digitalreset [if_idx][ch_idx]), .rx_analogreset (rx_analogreset [if_idx][ch_idx]), .rx_digitalreset (rx_digitalreset [if_idx][ch_idx]), .rx_analogreset_stat (rx_analogreset_stat [if_idx][ch_idx]), .rx_digitalreset_stat (rx_digitalreset_stat [if_idx][ch_idx]), .tx_analogreset_stat (tx_analogreset_stat [if_idx][ch_idx]), .tx_digitalreset_stat (tx_digitalreset_stat [if_idx][ch_idx]), .rx_is_lockedtodata (rx_is_lockedtodata [if_idx][ch_idx]), .tx_cal_busy (tx_cal_busy [if_idx][ch_idx]), .rx_cal_busy (rx_cal_busy [if_idx][ch_idx]) ); always_ff @(posedge tx_clk[if_idx] or negedge tx_arst_n[if_idx][ch_idx]) begin if(~tx_arst_n[if_idx][ch_idx]) begin prbs_insert_error_hssi_q[if_idx][ch_idx] <= '0; prbs_insert_error_hssi_e[if_idx][ch_idx] <= '0; end else begin prbs_insert_error_hssi_q[if_idx][ch_idx] <= prbs_insert_error_hssi[if_idx][ch_idx]; prbs_insert_error_hssi_e[if_idx][ch_idx] <= prbs_insert_error_hssi[if_idx][ch_idx] & !prbs_insert_error_hssi_q[if_idx][ch_idx]; end end resync #( .SYNC_CHAIN_LENGTH (2), .WIDTH (1), .INIT_VALUE (0), .NO_CUT (0) ) inst_prbs_seriallpbken_sync ( .clk (rx_clk[if_idx][ch_idx]), .reset (1'b0), .d (rx_seriallpbken [if_idx][ch_idx]), .q (rx_seriallpbken_hssi [if_idx][ch_idx]) ); // assign the rxclk assign rx_clk[if_idx][ch_idx] = hssi[if_idx].f2a_rx_clkout[ch_idx]; // Generate resets based off PLL locks assign hssi_reset[if_idx][ch_idx] = !plls_locked[if_idx] | cr2hssi_reset[if_idx][ch_idx]; always_ff @(posedge tx_clk[if_idx] or posedge hssi_reset[if_idx][ch_idx]) begin if(hssi_reset[if_idx][ch_idx]) begin {tx_arst_n[if_idx][ch_idx],tx_arst_n_d[if_idx][ch_idx]} <= '0; end else begin {tx_arst_n[if_idx][ch_idx],tx_arst_n_d[if_idx][ch_idx]} <= {tx_arst_n_d[if_idx][ch_idx],1'b1}; end end always_ff @(posedge rx_clk[if_idx][ch_idx] or posedge hssi_reset[if_idx][ch_idx]) begin if(hssi_reset[if_idx][ch_idx]) begin {rx_arst_n[if_idx][ch_idx],rx_arst_n_d[if_idx][ch_idx]} <= '0; end else begin {rx_arst_n[if_idx][ch_idx],rx_arst_n_d[if_idx][ch_idx]} <= {rx_arst_n_d[if_idx][ch_idx],1'b1}; end end // when tx are constant value, rx_value stays asserted // Bolt-up PRBS generator to TX side of PHY always_ff @(posedge tx_clk[if_idx] or negedge tx_arst_n[if_idx][ch_idx]) begin if(!tx_arst_n[if_idx][ch_idx]) begin hssi[if_idx].a2f_tx_parallel_data[(ch_idx*80)+79:(ch_idx*80)] <= '0; end else begin hssi[if_idx].a2f_tx_parallel_data[(ch_idx*80)+31:(ch_idx*80)] <= prbs_dout[if_idx][ch_idx];//{prbs_dout[if_idx][ch_idx][31:1], // prbs_dout[if_idx][ch_idx][0] ^ prbs_insert_error_hssi_e[if_idx][ch_idx]}; hssi[if_idx].a2f_tx_parallel_data[(ch_idx*80)+36] <= 1'b1; // tx_enh_data_valid hssi[if_idx].a2f_tx_parallel_data[(ch_idx*80)+79] <= 1'b1; // tx_fifo_wr_en end end // Bolt-up RX side of PHY to PRBS checker and drive serial loopback low for now always_ff @(posedge rx_clk[if_idx][ch_idx] or negedge rx_arst_n[if_idx][ch_idx]) begin if(!rx_arst_n[if_idx][ch_idx]) begin hssi[if_idx].a2f_rx_seriallpbken[ch_idx] <= '0; prbs_din[if_idx][ch_idx] <= '0; rx_data_valid[if_idx][ch_idx] <= '0; end else begin hssi[if_idx].a2f_rx_seriallpbken[ch_idx] <= rx_seriallpbken_hssi[if_idx][ch_idx]; prbs_din[if_idx][ch_idx] <= hssi[if_idx].f2a_rx_parallel_data[(ch_idx*80)+31:(ch_idx*80)]; rx_data_valid[if_idx][ch_idx] <= hssi[if_idx].f2a_rx_parallel_data[(ch_idx*80)+79]; end end assign prbs_pause_gen[if_idx][ch_idx] = prbs_pause_hssi_tx[if_idx][ch_idx]; assign prbs_pause_chk[if_idx][ch_idx] = prbs_pause_hssi_rx[if_idx][ch_idx] | !rx_data_valid[if_idx][ch_idx]; assign tx_count_reset_n[if_idx][ch_idx] = cr2ctr_tx_reset_n[if_idx][ch_idx] & tx_arst_n[if_idx][ch_idx]; assign rx_count_reset_n[if_idx][ch_idx] = cr2ctr_rx_reset_n[if_idx][ch_idx] & rx_arst_n[if_idx][ch_idx]; pattern_gen #( .MAX (32'hFFFF_FFFF), .prbs_initial_value (32'h5555_5555), .width (PRBS_DATA_WIDTH), .pattern ("prbs31") ) inst_pattern_gen ( .clk (tx_clk [if_idx]), .reset (~tx_arst_n [if_idx][ch_idx]), .data_out (prbs_dout [if_idx][ch_idx]), .enable (~prbs_pause_gen [if_idx][ch_idx]), .valid (prbs_gen_data_valid [if_idx][ch_idx]) ); pattern_ver_pipelined #( .MAX (32'hFFFF_FFFF), .prbs_initial_value (PRBS_INITIAL_VALUE), .width (PRBS_DATA_WIDTH), .pattern ("prbs31") ) inst_pattern_ver ( .clk (rx_clk [if_idx][ch_idx]), .reset (~rx_arst_n [if_idx][ch_idx]), .data_in (prbs_din [if_idx][ch_idx]), .data_locked (prbs_lock_hssi_rx [if_idx][ch_idx]), .error (prbs_error_flag [if_idx][ch_idx]), .enable (~prbs_pause_chk [if_idx][ch_idx]) ); // rx/tx counters always_ff @(posedge tx_clk[if_idx] or negedge tx_count_reset_n[if_idx][ch_idx]) begin if(!tx_count_reset_n[if_idx][ch_idx]) begin prbs_tx_count_hssi[if_idx][ch_idx] <= '0; end else if (!(prbs_pause_gen[if_idx][ch_idx])) begin prbs_tx_count_hssi[if_idx][ch_idx] <= prbs_tx_count_hssi[if_idx][ch_idx] + 1; end end always_ff @(posedge tx_clk[if_idx] or negedge tx_count_reset_n[if_idx][ch_idx]) begin if(!tx_count_reset_n[if_idx][ch_idx]) begin prbs_tx_err_count_hssi[if_idx][ch_idx] <= '0; end else if (prbs_insert_error_hssi_e[if_idx][ch_idx]) begin prbs_tx_err_count_hssi[if_idx][ch_idx] <= prbs_tx_err_count_hssi[if_idx][ch_idx] + 1; end end always_ff @(posedge rx_clk[if_idx][ch_idx] or negedge rx_count_reset_n[if_idx][ch_idx]) begin if(!rx_count_reset_n[if_idx][ch_idx]) begin prbs_rx_count_hssi[if_idx][ch_idx] <= '0; end else if (!(prbs_pause_chk[if_idx][ch_idx] | prbs_error_flag[if_idx][ch_idx])) begin prbs_rx_count_hssi[if_idx][ch_idx] <= prbs_rx_count_hssi[if_idx][ch_idx] + 1; end end always_ff @(posedge rx_clk[if_idx][ch_idx] or negedge rx_count_reset_n[if_idx][ch_idx]) begin if(!rx_count_reset_n[if_idx][ch_idx]) begin prbs_rx_err_count_hssi[if_idx][ch_idx] <= '0; end else if (prbs_error_flag[if_idx][ch_idx] & !prbs_pause_chk[if_idx][ch_idx]) begin prbs_rx_err_count_hssi[if_idx][ch_idx] <= prbs_rx_err_count_hssi[if_idx][ch_idx] + 1; end end avst_sync tx_count_bridge ( .in_clk(tx_clk[if_idx]), .in_reset(!tx_count_reset_n[if_idx][ch_idx]), .out_clk(clk), .out_reset(softReset), .in_ready(), .in_valid('1), .in_data(prbs_tx_count_hssi[if_idx][ch_idx]), .out_ready('1), .out_valid(prbs_tx_count_en[if_idx][ch_idx]), .out_data(prbs_tx_count_d[if_idx][ch_idx]) ); avst_sync tx_err_count_bridge ( .in_clk(tx_clk[if_idx]), .in_reset(!tx_count_reset_n[if_idx][ch_idx]), .out_clk(clk), .out_reset(softReset), .in_ready(), .in_valid('1), .in_data(prbs_tx_err_count_hssi[if_idx][ch_idx]), .out_ready('1), .out_valid(prbs_tx_err_count_en[if_idx][ch_idx]), .out_data(prbs_tx_err_count_d[if_idx][ch_idx]) ); avst_sync rx_count_bridge ( .in_clk(rx_clk[if_idx][ch_idx]), .in_reset(!rx_count_reset_n[if_idx][ch_idx]), .out_clk(clk), .out_reset(softReset), .in_ready(), .in_valid('1), .in_data(prbs_rx_count_hssi[if_idx][ch_idx]), .out_ready('1), .out_valid(prbs_rx_count_en[if_idx][ch_idx]), .out_data(prbs_rx_count_d[if_idx][ch_idx]) ); avst_sync rx_err_count_bridge ( .in_clk(rx_clk[if_idx][ch_idx]), .in_reset(!rx_count_reset_n[if_idx][ch_idx]), .out_clk(clk), .out_reset(softReset), .in_ready(), .in_valid('1), .in_data(prbs_rx_err_count_hssi[if_idx][ch_idx]), .out_ready('1), .out_valid(prbs_rx_err_count_en[if_idx][ch_idx]), .out_data(prbs_rx_err_count_d[if_idx][ch_idx]) ); always_ff @(posedge clk) begin if(softReset) begin prbs_tx_count[if_idx][ch_idx] <= '0; end else if (prbs_tx_count_en[if_idx][ch_idx]) begin prbs_tx_count[if_idx][ch_idx] <= prbs_tx_count_d[if_idx][ch_idx]; end end always_ff @(posedge clk) begin if(softReset) begin prbs_tx_err_count[if_idx][ch_idx] <= '0; end else if (prbs_tx_err_count_en[if_idx][ch_idx]) begin prbs_tx_err_count[if_idx][ch_idx] <= prbs_tx_err_count_d[if_idx][ch_idx]; end end always_ff @(posedge clk) begin if(softReset) begin prbs_rx_count[if_idx][ch_idx] <= '0; end else if (prbs_rx_count_en[if_idx][ch_idx]) begin prbs_rx_count[if_idx][ch_idx] <= prbs_rx_count_d[if_idx][ch_idx]; end end always_ff @(posedge clk) begin if(softReset) begin prbs_rx_err_count[if_idx][ch_idx] <= '0; end else if (prbs_rx_err_count_en[if_idx][ch_idx]) begin prbs_rx_err_count[if_idx][ch_idx] <= prbs_rx_err_count_d[if_idx][ch_idx]; end end end // block: HSSI_CH end // block: HSSI_IF endgenerate endmodule // prbs_top
