STRATIX 10 JTAG Configure problem
Device: Stratix 10 1SX280HH3F55E2VG
SOFTWARE: Quartus 19.1
Encounter a configuration problem, as follows:
Can identify the JTAG chain, where FPGA0 can download the sof file normally, FPGA1 fails to download the sof file, stuck at 2%
The prompt is as follows: (specifically as shown in the figure below)
Error (18950): Device has stopped receiving configuration data
Error (18947): Device not responding
Error (209012): Operation failed
At present, only one of the several boards has such a problem.
Tried changing MSEL to JTAG ONLY mode has no effect.
May I ask what may be the cause.
- YuanLi_S_Intel
The error means that the VID setting is not correct for the device. Can you take a look at our Stratix 10 power user guide? You will need to follow the setting available in it.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-pwr.pdf (Page 26)
- hzhan133
USB Blaster I.
It is difficult to determine the specific error from the error message. Please try these two methods first:
1. Quartus project do not bring GXB, DDR, or EMIF, only do the simplest lighting project
A: The error has changed. The prompt may be a PMBUS configuration problem, but this SOF configuration file is OK on other boards or different FPGAs of the same board. For details, please refer to the attachment
- YuanLi_S_Intel
May i know what USB Blaster you are using? II or I? Can you change the TCK frequency to 6MHz and try again?
Thank You
