Stratix 10 I2C IP Maximum speed of Operation
Please understand my query,
I am not asking for I2C soft IP speed and its limitations. My query is not around I2C, my question is all about
open-drain IOs that come with stratix-10 device.
Please let me know - what is the max speed the open-drain IO can operate ?
Kiran
so, do you mean - that Stratix-10 open-drain IO is limited to operate upto max 400KHz, time-constant of open-drain IO does not support to run beyond 400Khz ? Please request for a binary answer.
- FvM1 year ago
You did not refer to IO speed in initial posts, really confusing. Speed of open drain is surely not limited to 400 kHz, it can be affected by varying the pull-up resistors. 400 kHz for fast mode has been specified in I2C standard to support common applications. Details are discussed here https://www.nxp.com/docs/en/user-guide/UM10204.pdf
I suggest to check the achievable speed for your actual hardware, at least HPS I2C interface should allow to adjust speed.
- kiransr1 year ago
Please understand the Question carefully
I am not using the I2C IP from Startix device, I have designed a soft I2C master module, would like to run this I2C master IP at 1Mhz or above, but can i use this IP and connect it to stratix open-drain IO,
will the IO support 1Mhz speed or not ?
