Stratix 10 I2C IP Maximum speed of Operation
documentation clearly specifies to support 400 kHz maximal. To find out what's the actual limitation, you probably need to get familiar with the documentation and IP core details yourself.
In case of soft I2C IP, speed is fixed to 100 and 400 kHz, there's one bit to switch between both. Using a different speed would require to modify the IP source code.
Stratix 10 HPS has preset SCL high and low clock tic counts for standard and fast mode. I read the documentation so, that lower counts are possible (see 20.4.5.1. Minimum High and Low Counts). If I2C can actually operate with lower settings must be tested.
I2C operation speed is not only limited by controller timing but also by time constant (pull-up resistor and load capacitance) of open drain bus. Intel I2C IP doesn't support push-pull bus drivers for Hs mode.
Please understand my query,
I am not asking for I2C soft IP speed and its limitations. My query is not around I2C, my question is all about
open-drain IOs that come with stratix-10 device.
Please let me know - what is the max speed the open-drain IO can operate ?
Kiran
- kiransr1 year ago
so, do you mean - that Stratix-10 open-drain IO is limited to operate upto max 400KHz, time-constant of open-drain IO does not support to run beyond 400Khz ? Please request for a binary answer.
- FvM1 year ago
You did not refer to IO speed in initial posts, really confusing. Speed of open drain is surely not limited to 400 kHz, it can be affected by varying the pull-up resistors. 400 kHz for fast mode has been specified in I2C standard to support common applications. Details are discussed here https://www.nxp.com/docs/en/user-guide/UM10204.pdf
I suggest to check the achievable speed for your actual hardware, at least HPS I2C interface should allow to adjust speed.
- kiransr1 year ago
Please understand the Question carefully
I am not using the I2C IP from Startix device, I have designed a soft I2C master module, would like to run this I2C master IP at 1Mhz or above, but can i use this IP and connect it to stratix open-drain IO,
will the IO support 1Mhz speed or not ?
