Stratix 10 I2C IP Maximum speed of Operation
Hi
Sorry to mention that the Stratix10 only supports up to Fast Mode of the I2c protocol.
For the Stratix10 I2C controller maximum speed is up to 400Khz.
This is mentioned in the Stratix10 TRM :
https://www.intel.com/programmable/technical-pdfs/683222.pdf
It is the same if you are using the I2C Host IP :
https://www.intel.com/content/www/us/en/docs/programmable/683130/22-1/core-overview-35558.html
Jingyang, Teh
- kiransr1 year ago
Hi Jingyang,
Please let me know -
Are there Open-Drain IO pads in Stratix 10 device that can run at 1Mhz or above?
Kiran
- kiransr1 year ago
Hi Jingyang Teh,
Thank you for the answer.
If we port ASIC verified I2C (our own I2C module, which can run at 1.3Mhz) to stratix 10 FPGA then will the IO's support the same speed as ASIC (1.3Mhz) or will it be restricted to 400Khz.
Kiran
