Eduard_B_Intel
7 years agoStratix 10 GX setup issues
Hello, Please, help! Brand new Stratix 10 GX board is not recognised as a PCIe device. Linux lspci doesn't show the device when device is plugged into ePCI slot. BTS(Board Test System) doesn't see...
JohnT_Altera
7 years agoHi,
I suspect that you didn't enable the Stratix 10 device in your JTAG chain. If my understanding, is correct then please change the SW6.1 to OFF to enable it. You may refer to Table 5 of the user guide.
May I know if you are using Quartus Pro edition? If not, you will need to install Quartus Pro edition in order for it to support Stratix 10 device.
