Stratix 10 E-tile Transceiver Native PHY : questions with "altera_xcvr_rcfg_10_reconfig_parameters.m
Some questions about the "altera_xcvr_rcfg_10_reconfig_parameters.mif" file:
1.What if the bits of the registers that are not written to are not used?
for example :
00F : 00013C000; -- [34:16]-DPRIO address=0x013; [15:8]-bit mask=0xC0; [7:7]-
hssi_xcvr_rxfifo_wr_full=prevent_wr_rx_fifo_full(1'h0); [6:6]-
hssi_xcvr_rxfifo_rd_empty=prevent_rd_rx_fifo_empty(1'h0);
if data[5:0] are unsed,Writing these bits has no effect?
2.Can you give the description of an unlisted address, such as 0xe8?
Thank you
1 Reply
- Kshitij_Intel
1) With reference to the example provided in the user guide, it seems to have no effect. Please refer to the link below for mor info.
https://www.intel.com/content/www/us/en/docs/programmable/683723/current/reconfiguration-files.html
2) Please only use the registers which are defined in the user guide, those registers might be used for some internal configuration.
Thank you
Kshitij Goel
