duanrac
6 years agoStratix 10 DSP preload constant
it's possible with DSP block of stratix 10 to use preload constant (for rounding) with accumulator ?
A(n+1)=(B*C)+A(n) + 1<<x
or it is exclusive mode?
A(n+1)=(B*C)+A(n)
or
A(n)=(B*C)+...
CheepinC_altera
6 years agoHi,
Thanks for your update. To help further verifying your target usage ie set LOADCONST and ACC on the same clock cycle, it is recommended for you to create a test design and run through the Modelsim simulation to check on the functionality to see if it is meeting your expectation.
Chee Pin
