Stratix 10 DSP preload constant
As I understand it, you have some inquiries related to preload constant in the S10 DSP block. For your information, I am not really a design specialist and could not comment your codes implementation into the DSP block. However, you may refer to the DSP preload constant feature details in the Intel® Stratix® 10 Variable Precision DSP Blocks User Guide (
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-dsp.pdf) -> "2.7. Accumulator, Chainout Adder, and Preload Constant for FixedPoint Arithmetic" for further details on the supported preload constant feature to see if this is something that you are looking for.
- duanrac6 years ago
Thank you for your answer.
yes I refer to this documentation.
It's not clear for me in, this documentation if it's possible to set LOADCONST signal and ACCUMULATE signal on same clock cycle to do in same time rounding and accumulate.
