Stratix 10 Access
Hi @royak,
It seems that your environment setup on your local platform might now have devcloud_login command configured.
I assume you are having Windows OS and using some tool to perform ssh connectivity, would suggest to follow the OpenSSH as it is recommended.
If you are using other ssh tools like mobaxterm there is a steps to configure the 'devcloud_login' is required. Please refer to the steps 5.2 in the link below.
Note: Mobaxterm are in the deprecated path.
Best Wishes
BB
- royak3 years ago
I am running the intel devcloud though a shell in my terminal on my MacOs. Other than the initial "hello world" script, I haven't done much else to configure my environment. I am still having trouble finding the option to select a Stratix node. Is there any other infomation you need to help me out?
Thank you very much for your time and sorry for late response.
