Stratix 10 Access
Hi @royak,
Thank you for posting in Intel community forum and hope all is well.
With the assumption that you have managed to connect to Intel DevCloud successfully, the command to access the node are just by running the 'devcloud_login' command and you should be prompt with the desire node to select.
Hope that clarify.
Note: for more information on DevCloud available command you can refer to the link here --> https://devcloud.intel.com/oneapi/documentation/shell-commands/
Best Wishes
BB
- royak3 years ago
So, I have set up my devcloud and configured the environment. I sign in with no issues using "ssh devcloud" and have successfully run the "hello world" script using a gpu node. However, when I run 'devcloud_login,' I am told "command not found." Is this a problem with how I configured my shell?
Thanks for your time,
Roy
