12 years agoStratix 1 to Arria V conversion
I've been tasked with converting a 10 year old Stratix 1 design (EP1S25F672I7, Quartus 3.0, SP1) to a Arria V design (5AGXBA1D4F27I5, Quartus 13.1). So, I have to deal with migrating to a different ...
12 years agoHere's what I'd recommend;
1. Download Quartus 3.0sp1 and rebuild the design. This step confirms that you have a known-good starting point. 2. Copy-and-paste the project to a new folder and open that copy with the last version of Quartus that supports the Stratix 1 series (which might be 14.0, but you'd have to check). 3. Rebuild the project; fix issues related to old IP and missing SDC constraints. At this point you have basically upgraded the Stratix 1 design. You'd then work on the switch to Arria V. Pin constraints and other assignments can be written into a Tcl script. At the end of this process, it would be possible for you to have a Tcl script that can synthesize the project code for either the Stratix 1 board or the new Arria V board. That Tcl script would decide which constraints to pull into the project. For now, stick with the GUI and gain a sense of how many issues you're going to face. Cheers, Dave
