9 years agoStrange effects with NIOS in design
Hi everyone, For the first time I am using a NIOS soft core in one of my designs. Generating the core was relatively easy but now I'm facing some strange effects when I integrate the core into ...
9 years agoI don't have an answer for you, but you can see pinout details for your device here: https://www.altera.com/support/literature/lit-dp.html
AC23 is listed as having the partial reconfiguration request signal as a configuration function, but I doubt that has anything to do with your issue (unless for some reason you've enabled the external PR pins in the Device settings). Have you checked the compilation report for these pins? Perhaps there is a message in there somewhere that might explain what's going on.
