storing link rates in ATX PLL
Hi Rajesh,
Regarding your latest inquiry if you can use the existing logic from display port for ATX PLL, sorry as I do not have visibility into the display port logic and could not really comment. However, based on my understanding, ATX PLL and fPLL should have differences in the internal architecture and registers, I believe you cannot directly use the existing logic.
I would suggest you to open a new thread with request specific to replacing ATX PLL in the DP IP generated design example so that our DP expert could further assist.
Chee Pin
<I believe you cannot directly use the existing logic>
Yes i cannot, i will modify the logic
but Does ATX pll supports storing link rate feature ?
Rajesh
