storing link rates in ATX PLL
Hi Rajesh,
Thanks for your update. You are right. After performing the dynamic reconfiguration for ATX PLL, you should perform a recalibration to ensure it can function properly. As for the saving of calibration results, sorry as I am not aware of this with the ATX PLL. Probably the example code on Displayport has some customization prepared by Factory.
Chee Pin
- Rk_Athram5 years ago
In display port design for FPLL is used, which having registers to store the frequency band, the similar registers are not available for ATX PLL.
SNAPSHOT FROM A10 register map excel sheet.
I need to figure out whether i can use the existing logic from display port for switching speed when i use ATX PLL?
or i must use only "Multiple Reconfiguration Profiles" for switch between the speed ?
If possible, please confirm from internal team about my query!
Rajesh
