18 years agostate machine view problem, need help
I am new to this forum. Recently I started learning Altera. I was trying to compile combinational bench mark file s27.v and during compilation I got a warning : "dff" is an internal primitive and got...
18 years agos27 bench:
//# 4 inputs //# 1 outputs //# 3 D-type flipflops //# 2 inverters //# 8 gates (1 ANDs + 1 NANDs + 2 ORs + 4 NORs) module dff (CK,Q,D); input CK,D; output Q; wire NM,NCK; trireg NQ,M; nmos N7 (M,D,NCK); not P3 (NM,M); nmos N9 (NQ,NM,CK); not P5 (Q,NQ); not P1 (NCK,CK); endmodule module S27(GND,VDD,clk,G0,G1,G17,G2,G3); input GND,VDD,clk,G0,G1,G2,G3; output G17; wire G5,G10,G6,G11,G7,G13,G14,G8,G15,G12,G16,G9; dff DFF_0(clk,G5,G10); dff DFF_1(clk,G6,G11); dff DFF_2(clk,G7,G13); not NOT_0(G14,G0); not NOT_1(G17,G11); and AND2_0(G8,G14,G6); or OR2_0(G15,G12,G8); or OR2_1(G16,G3,G8); nand NAND2_0(G9,G16,G15); nor NOR2_0(G10,G14,G11); nor NOR2_1(G11,G5,G9); nor NOR2_2(G12,G1,G7); nor NOR2_3(G13,G2,G12); endmodule Warning: Entity "dff" will be ignored because it conflicts with Quartus II primitive name Summary Details: Flow Status Successful - Tue May 13 08:33:06 2008 Quartus II Version 7.2 Build 203 02/05/2008 SP 2 SJ Web Edition Revision Name s27 Top-level Entity Name s27 Family Stratix II Met timing requirements Yes Logic utilization < 1 % Combinational ALUTs 1 / 12,480 ( < 1 % ) Dedicated logic registers 0 / 12,480 ( 0 % ) Total registers 0 Total pins 8 / 343 ( 2 % ) Total virtual pins 0 Total block memory bits 0 / 419,328 ( 0 % ) DSP block 9-bit elements 0 / 96 ( 0 % ) Total PLLs 0 / 6 ( 0 % ) Total DLLs 0 / 2 ( 0 % ) Device EP2S15F484C3 Timing Models Final If I change "dff" to "dff1" all places in side the code with a modification in the dff module such as module dff1(clk,Q,D); input clk,D; output Q; reg Q; always @(posedge clk) begin Q<=D; end endmodule This shows 3 registers but software is not recognizing any state machines
