State machine crashes (Cyclone II) - no idea why. How do I debug?
- 6 years ago
State machines usually crash because they entered into an illegal, undocumented state.
This can happen when an input signal that is sampled is either asynchronous, or poorly synchronized.
The signal goes to two separate parts of the state machine transition logic, and is interpreted as a H in one part, and a L in the other.
This can then cause a transition to an illegal state.
You don't show enough of your code to know how this might apply in your case. The module header, and how all input signals are generated, is necessary to know.
Quartus will on occasion re-encode the state machine in another form (usually one-hot) where each defined state is implemented as being encoded with just one state bit set. You need to look in your report files to see if this was done (or not). Doing this can be disabled by user control.
As you mention synchronous clock timing can also be a cause, but Quartus should be able to tell you which paths did not meet your 50MHz timing (if any).
Hello @RSree, thank for your reply, but the problem has been solved. It was not caused by bad power supply to the Cyclone II. I t was caused by my bad RTL coding.
I just could not understand why the state machine was crashing, as I had reviewed *my* code again and again. As a consequence I started to NOT trust my circuit/PCB hardware implementation, even though I used plently of decoupling capacitors and bulk caps too. But when I scoped the 1.2V core power supply, it was clean in the area where the crash was happening (I added the 1.2V trace to the above pictured conditions). I think that I was "clutching at straws" and bad power was the best idea I could come up with. Thankfully I was wrong!
Once it was clearly explained about the race condition of un-re-synchronoised inputs from other clock domains, the penny dropped. I changed the RTL to re-sync all inputs using standard "shift register" techniques. My (fixed) RTL is now solid and works perfectly. I am very relieved, and very importantly I am also confident that my hardware design using the Cyclone II can be trusted!
We learn by our mistakes, and I am actually pleased to have better understood how to code robust state machines. I have gone through all my RTL and made sure that I have fixed the same problem elsewhere in my code.
regards...
--migry
