14 years agoState A => State B multicycle path?
Is there a way to tell TimeQuest that all signals launched by State A and captured by State B are part of a multi-cycle path? My combinational path delay is too large so i'm adding a timer to delay m...
14 years agoKaz,
multicycle exceptions are not restricted to clock enables. Consider this example. Let's say we a have a state machine that in one clock is in stateA, next clock in stateB and next clock in stateC.always @ (posedge clk) begin
if (state == stateA) regA <= someValueA;
if (state == stateB) regB <= someValueB;
if (state == stateC) regC <= regA - 10 + regB;
end The synthesis tool may use clock enables to implement this behavior. Or it may simply implement them by feeding back the registers' output via a mux. But in both cases, we can set a multicycle exception of 2 for the path between regA and regC. What the multicycle exception tells TQ is that the transitions from regA and regC have 2 clocks to propagate. The transitions from regB to regC, however, still only have 1 clock to propagate.
