17 years agoStarting Process from another
Hi, i got a design using two state machine. The first process is starting the second process and then it wait until its done. Both processes are clocked on the rising edge of the same clock. ...
17 years agoBecause the signal will go low after the 2nd clock edge and the 2nd process will see the signal on the 2nd clock edge before it has been cleared by the first process.
The timing analyser works all this stuff out for you so as long as you meet your set up and hold times then you don't need to worry about it.
