17 years agoStarting Process from another
Hi, i got a design using two state machine. The first process is starting the second process and then it wait until its done. Both processes are clocked on the rising edge of the same clock. ...
17 years agoThanks for your fast response.
Could you please explain to me why this cant cause problems? I thought that if i set start_S with the rising edge and clear it with the next rising edge it is not sure that the signal is high when the clock edge arrives at the second process?!?
