17 years agoStarting Process from another
Hi, i got a design using two state machine. The first process is starting the second process and then it wait until its done. Both processes are clocked on the rising edge of the same clock. ...
17 years agoYou should only use the rising edge of the clock. As long as your design meets timing then you should have no problems with regards to clock edges.
