tfan2020
3 years agoSTA Timing result much worse with Quartus v20 and later than v17.1
I have a design implemented in Arria10 device, I'm using Synplify_premier v2019 + Quartus v17.1 Standard edition. Now I want to upgrade the Quartus version to v20 later, e.g. v22.1.
The iss...
Nurina
3 years agoHello,
Are you using Quartus Pro or Standard? These documents tells you how you can perform Automatic Gated Clock Conversion on Quartus Pro and Standard:
- https://www.intel.com/content/www/us/en/docs/programmable/683236/22-1/automatic-gated-clock-conversion.html
- https://www.intel.com/content/www/us/en/docs/programmable/683283/18-1/auto-gated-clock-conversion.html
This should be sufficient to convert gated clocks. However from a timing perspective, I cannot confirm if this would improve the slack because I do not know the root cause of the timing violation in your design.
You can share your design through e-mail for privacy purposes. I'll drop an e-mail to you.
Nurina
