SSH connection lost - Cannot copy executable file into de10-nano
- 1 year ago
Hi Varshasri
Sorry for the delay in getting back to you in this case and thanks to BXia for helping out in this case.
I suspect the issue is due to the IP address not being on the same network 192.168.3.111 vs 192.168.0.1 on your pc but it is strange when you have both PC and DE10 ethernet connected to the same router with different network. Could you check whether the IP is assigned via DHCP or static (defined by own ethernet settings) perhaps command "ip route list default" and see whether dhcp or static appear. If static you will need to change the IP manually or set back to dhcp. I think you could also go to your router page and see the list of devices IP connected to it with DHCP.
Alternatively you can follow what BXia suggested, which is to connect directly with both having same IP network and SCP in.
Kian
Hi Varshasri,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Kian
