SSH connection lost - Cannot copy executable file into de10-nano
- 1 year ago
Hi Varshasri
Sorry for the delay in getting back to you in this case and thanks to BXia for helping out in this case.
I suspect the issue is due to the IP address not being on the same network 192.168.3.111 vs 192.168.0.1 on your pc but it is strange when you have both PC and DE10 ethernet connected to the same router with different network. Could you check whether the IP is assigned via DHCP or static (defined by own ethernet settings) perhaps command "ip route list default" and see whether dhcp or static appear. If static you will need to change the IP manually or set back to dhcp. I think you could also go to your router page and see the list of devices IP connected to it with DHCP.
Alternatively you can follow what BXia suggested, which is to connect directly with both having same IP network and SCP in.
Kian
Hi Varshasri
Kian
- Varshasri1 year ago
Thank you so much, it worked!
I checked the IP to see if it was a DHCP or static, turns out it was static.
I changed it to DHCP and then I was successfully able to SCP into the board.
