17 years agoSRAM/SDRAM DE1 board.
Hi !! I need some help about SRAM/SDRAM memory, the thing I want to do is to read from any address on memory and send this data to led, and write data into memory from switchs(using DE1 board a...
17 years agoSorry I read your message too fast, I thought you meant you wanted to use the Nios processor.
In that case the SRAM is the easiest to interface. Just provide an address and read or write the data using the control signals. The SRAM datasheet should give you all the information you need. To use the SDRAM you'll need a controller. There are some controllers in Quartus' Megawizard but I'm not sure there is any for SDR chips. You may have more luck on the Opencores site.
