17 years agoSRAM/SDRAM DE1 board.
Hi !! I need some help about SRAM/SDRAM memory, the thing I want to do is to read from any address on memory and send this data to led, and write data into memory from switchs(using DE1 board a...
17 years agoWhat you need is a good tutorial on the C language, and then you can have a look at Altera's Nios tutorial. You should find there everything you need.
