17 years agosram and vga problem ?
Hi,everyone ! I'm trying to show a 1024*768*8 grayscale image on my lcd monitor.I've already written a vga interface, and it works. On my FPGA Bord , i have two 1MB sram. Here is my questions ? ...
17 years agoregarding my prev post...............
i thought i'd start reading a .bin file into the BRAM first before trying for the bmp file unfortunately the code is not responding: entity files is PORT( clk_in :in std_logic; output : out bit_vector(2 DOWNTO 0); out1 : out std_logic_vector(6 DOWNTO 0); we : in std_logic; input : in std_logic_vector(3 DOWNTO 0); rst: in std_logic); end files; architecture Behavioral of files is type ramtype is array(0 to 7) of bit_vector(2 downto 0); impure function file_io (inFile : in string) return ramtype is file Prog: text is in inFile; variable L: line; variable VALUE : bit_vector(2 DOWNTO 0); variable RAM1 :ramtype; begin for I in ramtype'range loop if NOT endfile(Prog) then readline (Prog, L); read (L, RAM1(I)); end if; end loop; return RAM1; end function; signal in_data : bit_vector(2 DOWNTO 0); signal RAM : ramtype := file_io("demo.bin"); signal address : std_logic_vector(3 DOWNTO 0); begin process (clk_in) IS begin if clk_in'EVENT and clk_in ='1' then if (we = '0') then RAM(conv_integer(input)) <= in_data; output <= in_data; else output<=RAM(conv_integer(input)); end if; end if; CASE input IS WHEN "0000"=>out1<="1000000"; WHEN "0001"=>out1<="1111001"; WHEN "0010"=>out1<="0100100"; WHEN "0011"=>out1<="0110000"; WHEN "0100"=>out1<="0011001"; WHEN "0101"=>out1<="0010010"; WHEN "0110"=>out1<="0000010"; WHEN "0111"=>out1<="1111000"; WHEN "1000"=>out1<="0000000"; WHEN "1001"=>out1<="0010000"; WHEN OTHERS=>NULL; END CASE; end process; end Behavioral; The in_data seems to be redundant and confusing , but if i dont assign the ram to an unassigned signal ie when we ='0' then the RAM is instantiated as distributed instead of BLOCK The bin file is just : demo.bin 000001010011100101110111 ( 0 to 7 in 3 bit) can anyone help me with this file_io problem... ? or is ther something fundamentally wrong with this approach
