SPI with DMA is not working?
Hi, everyone
I am using SPI Master Core on FPGA to transmit data to SPI slave (offboard device). I want to use DMA to free my NIOS for other tasks during SPI data transfer. My Idea is NIOS - DMA - SPI(master) <-> SPI (slave / extern device) I can not understand, how can it work. SPI master core send and receive data at the same time. After sending, e.g, 8 bits data I also have to read the 8 bits data in RXdata register which resets RRDY bit in status register. Otherwise I will get a ROE (Receive overrun error), If I send another 8 bits data. If I use DMA to send, e.g., 20 bytes data continiously without reading any data from SPI Rxdata, I will definetely get error and Sending will not be successful. Has someboby really used SPI with DMA to send data? How can it work? Thanks a lot!20 Replies
--- Quote Start --- Writing an MM-Slave wrapper around a general SPI-master is not that difficult. What specific device is your external SPI slave? --- Quote End --- It is a MPU serial Interface consisting of serial clock SCLK, serial data SDIN, D/C (data/command), and ChipSelect. this SPI is used to receive display command and data. To control D/C I generated a PIO. To serial data SDIN is MOSI of SPI in FPGA. And MISO of SPI in FPGA is not used. What do U mean "Writing an MM-Slave wrapper around a general SPI-master is not that difficult." I tested sending data to SPI with DMA. But without reseting RXdata I can only send Txdata twice due to, I think, receive overrun error. My Idea is to shut off Rxdata path and its Error bit of status register in SPI master on FPGA. Is it possible? Thanks all of U guys and have a good day. - Altera_Forum
Well then it's easy to create Your own component :)
What specific device is your external SPI slave? - Altera_Forum
But sorry, The avalon Streaming (Avalon-ST) SPI core is an SPI slave. And my offboard SPI Interface is also Slave.
Hi thanks, this post makes sence. PS.: I am a beginner of Altera FPGA and may ask lots of stupid questions.:)
SPI with Avalon-ST is a different component than simple SPI, which has Avalon-MM interface, so there are no interrupts, no overrun errors and that kind of stuff! Either You don't understand what I am talking about or this task is too difficult for You.
Thanks again Socrates!
I don't think it is a problem with DMA or SGDMA, but with SPI. I must receive RXdata everytime I have sent TXdata. Or I would get Receiver Overrun Error. I don't want to interrupt Txdata channel after each sending in order to receive unused Rxdata and so to reset RRDY bit in status register. has somebody Idea? - Altera_Forum
I've not used SPI with Avalon-ST interface, but since it's a streaming interface, there should be no problems if You will not use data reception part, since it's not keeping data in any buffer. Check documentation.
Thanks U a lot dear Socrates
Do U have an Example ? QSys & Source Code. If I use SGDMA, I will need a SGDMA memory to steam for TX. Do I also need a SGDMA stream to memory for RX to avoid RX overrun error? I do not need to receive data. - Altera_Forum
Why not to use SPI to Avalon-ST and SGDMA? SGDMA would transfer the data, when SPI core is ready.
