LFrin's avatar
LFrin
8 years ago
Speed Transceiver-Channel near PCIe Hard IP Blocks
I use the FPGA Cyclone V GT "5CGTFD7C5F23I7N".
I'm wondering if the speed of the transceiver channels next to the PCIe Hard IP Blocks is limited? Can these channels also be used as 5 Gbps transceivers?
  • SengKok_L_Intel's avatar
    SengKok_L_Intel
    The key concern is the CMU PLL, if you don't use it for PCIe Hard IP, I don't see there is a limitation.
    Regards -SK ​
  • LFrin's avatar
    LFrin
    Thanks for your answer, I asked the question wrong.
    I do not use the PCIe Hard IP Blocks, therefore the question is: If the speed of the transceiver channels next to unused PCIe Hard IP Blocks is limited? I'm afraid I can't use these channels as 5 Gbps transceivers.
