10 years agoSpecifying LUT's
I'm currently trying to port the CERN WhiteRabbit TDC, which was originally written for Spartan FPGAs, to Cyclone4. The code contains a ring oscillator build out of hand specified LUTs:architecture rtl of tdc_ringosc is
signal s: std_logic_vector(g_LENGTH downto 0);
attribute keep: string;
attribute keep of s: signal is "true";
begin
g_luts: for i in 0 to g_LENGTH-1 generate
g_firstlut: if i = 0 generate
cmp_LUT: LUT2
generic map(
INIT => "0100"
port map(
I0 => s(i),
I1 => en_i,
O => s(i+1)
end generate;
g_nextlut: if i > 0 generate
cmp_LUT: LUT1
generic map(
INIT => "01"
port map(
I0 => s(i),
O => s(i+1)
end generate;
end generate;
s(0) <= s(g_LENGTH);
clk_o <= s(g_LENGTH);
end architecture;
There does not seem to be an equivalent primitive for Cyclone/quartus that supports the same functionality. It seems that either LUT_INPUT/LUT_OUTPUT or LCELL should be used instead, but I cannot figure out how to use them. The documentation of the primitives is short, at best, the "Designing with Low-Level Primitives" user guide does not contain more info and the Stratix Advanced Synthesis Cookbook does not mention them at all. Could you point me to a description of how to use these primitives or something else I could use instead to solve this problem? Thanks in advance3 Replies
Altera doesnt provide support for configuring luts to the same level that Xilinx does.
It provides specific gate functions (AND, OR) etc, but I also cannot find an ALUT as a configurable primitive. You can find them in in <install dir>/quartus/libraries/primitives - Altera_Forum
LUT* takes the value of INIT as a bit string that defines its output. The input pins are used as an address into this string.
The LUT1 is basically just a buffer element while the LUT2 implements an AND gate with an inverted input to start/run the ring oscillator. No, a PLL does not work. The ring oscillator is there to measure the effects of temperature and voltage variation on the chip to compensate those variations in the delay chain used for the TDC itself. You can find the details of the design in http://www.ohwr.org/attachments/855/tdc_v3.pdf Yes, I know that I will have to do some manual placement to get things to work correctly. This is to be expected when building TDCs. - Altera_Forum
... and what the definition for LUT1 and LUT2... <- doesn't matter
It seems clock generated from logic (one-shot multivibrator) <- if you read book you saw many exclamation about it perhaps it is better to redesign block so you get managable value for output frequency (1) no dependacy logic elements are placed somewhere far from each other in the chip (2) why you do not want to use external clock with PLL?
