14 years agosource synchronous interface or virtual clock?
My FPGA is connected to an ADC. There are three interface signals between them : SCLK and DOUT, which are outputs from FPGA, and DIN, input from ADC. SCLK is generated by dividing the system c...
14 years ago --- Quote Start --- (3) You can't do a virtual clock based on a generated clock. I tried the same thing and .sdc syntax doesn't allow it. So you just use the generated clcok on sclk for your input. --- Quote End --- Really? I use the following constraints and it is accepted: create_generated_clock -name SCLK_ADC1 -source [get_pins {inst15|altpll_component|auto_generated|pll1|clk[0]}] -divide_by 4 [get_ports {SCLK_ADC1}] create_generated_clock -name SCLK_ADC1_virt_in -source [get_ports {SCLK_ADC1}] Here is the Clocks Summary in TimeQuest: http://www.alteraforum.com/forum/attachment.php?attachmentid=5011&stc=1&d=1320735423
