14 years agosource synchronous interface or virtual clock?
My FPGA is connected to an ADC. There are three interface signals between them : SCLK and DOUT, which are outputs from FPGA, and DIN, input from ADC. SCLK is generated by dividing the system c...
14 years agoThank you for the reply, Rysc.
Yes, the max clock rate of ADC is only 20MHz (it is AD7928 of Analog Devices). I assume in this case, using source synchronous style or virtual clock will not make a big difference in the result of timing analysis, but source synchronous style is more correct in concept. Am I right in saying so? I compare the results of timing analysis with these two methods. Under the same contraint, it seems TQ estimates a smaller clock uncertainty of SCLK in source synchronous style than it does in virtual clock.
