14 years agosource synchronous interface or virtual clock?
My FPGA is connected to an ADC. There are three interface signals between them : SCLK and DOUT, which are outputs from FPGA, and DIN, input from ADC. SCLK is generated by dividing the system c...
14 years agoThe path to sclk is relevant on both sides, so you want to constrain the output source-synchronous style. For the input, you also use sclk as the set_input_delay -clock option, where the -max and -min are the longest and shortest round-trip delay from the time sclk leaves the FPGA to data coming back.
What is the clock rate? I've never heard of an ADC not sending a clock with its data. I assume it is quite slow, as that's not a very fast way to make an interface.
