16 years agosorting time issue
Hi, I want to calculate the time taken to sort the files alphabetically. I am using timestamp driver. In the output gives me the sorted file names but the the time taken to sort it is always z...
16 years agoHello,
Here are some points that I would check first : - Are you sure you have a timestamp component in your system ? - Check the value returned by alt_timestamps_start() (0 if success) - Which value return alt_timestamps_frequency() ? - the // before your sort function is just here, it is not really in your code (just to be sure) ? Jérôme
