12 years agosorter in vhdl
hi every one i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that he...
12 years agoThat looks ok to me.
your address(duration) is: 16,8,32,9,48 your data(trigraph) is: 10,20,30,40,50 due to one bit shift + 1 your data becomes 2*10+1 = 21 and so on then reverse that at output 101/2 -1 = 50 to avoid confusion you can use bit(8) as flag
