12 years agosorter in vhdl
hi every one i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that he...
12 years agoi try to write this code
is it as you suggest kaz library ieee; use ieee.std_logic_1164.all; use IEEE.numeric_std.all; entity bubblesort is port( clk : in std_logic; we : in std_logic; trigraph : in std_logic_vector(7 downto 0); duration : in integer range 0 to 1023 ; rd_duration : in integer range 0 to 1023; rd_trigraph : out std_logic_vector(7 downto 0) ); end entity; architecture rtl of bubblesort is type mem is array(0 to 1023) of std_logic_vector(7 downto 0); signal ram : mem := ((others=> (others=>'0'))); signal n,i : integer range 0 to ram'length; begin process(clk) begin if(rising_edge(clk)) then if(we = '1') then n <= 0; i <= 0; ram(duration) <= trigraph; end if; end if; if(rising_edge(clk)) then if (we= '0') then rd_trigraph <= ram(rd_duration); end if; end if; if (n < ram'length) then if (i < ram'length-1) then if (ram(i) > ram(i+1)) then ram(i) <= ram(i+1); end if; i <= i+1; else i <= 0; n <= n+1; end if; end if; end process; end rtl ;
