12 years agosorter in vhdl
hi every one i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that he...
12 years agohi kaz
i want first to thank you very much i have finished the part of authentication mode i would not finish it without you help . now if i have two input first for codes std_logic_vector ( 0 to 7) and the second for its time which is in integer type ,such as 00000001 ------> 125 ms 00010010 ------> 100 ms 01000100 ------> 200 ms 01111000 ------> 147 ms and i want to sort them as the following 00010010 ------> 100 ms 00000001 ------> 125 ms 01111000 ------> 147 ms 01000100 ------> 200 ms so, i want to sort the second input in ascending order and the corresponding firt input data to it i hope to understand me and help me to start that code. sorry for bad english
