12 years agoSOPC/QSYS connect 32 bits avalon slave to a 8 bits SRAM
Hi everyone my name is Alban, EE & embedded systems engineer, Strasbourg, France I made and 512k x 8bits SRAM expansion for my Cyclone II EP2C8 dev board i would like to make it acces...
12 years agohi it's me again
8 bits avalon MMslave seems to work, but not optimized for speed i verified all access types using my oscilloscope, trigged on the falling edge of the chip select signal writes : 1> a char takes 1 write cycle. 2> a short int takes 2 write cycles. a short integer needs to be "2 bytes aligned" in memory 3> a int takes 4 write cycles. a short integer needs to be "4 bytes aligned" in memory read : 1> a char takes 4 read cycle. the address bus spans all 4 bytes of a "4 bytes aligned" location in memory, and the NIOS selects the first, second third or fourth byte depending on the location of the byte that you need to read for 2> a short int takes 4 read cycle. same as above. the nios selects the first or the last two bytes. short int must be "2 byte aligned" 3> a int takes 4 read cycle. int must be "4 bytes aligned" how do i create an avalon MM slave that allows reading times to be just as the same as the writing times ? do i need to use byte enables ? THANK YOU FOR HELPING Best regards Alban
