15 years agoSOPC Generates Failing Paths
Hi all, I generated 8 Master templates (read and write together) and one slave sdram component. When i compile the device gives the warning timing requirements not met. In the timingsadviso...
15 years agoThen i have another question. as said above i use 8 Master Templates thas uses 1 Slave SDRAM controller.
If all templates do an action read or write at the same time... Will the arbiter handle every action sequentially or will only one action be completed and the others lost? Or what components would u use, within the sopc? Is it enough with one Pipelined bridge ?
