17 years agoSOPC error with pipeline bridge
Hello, To increase my SOPC system fmax, i'm trying to use an AVALON-MM pipeline bridge between 2 masters (the NIOS cpu and a sgdma master) to interface a flash memory and a ssram memory (throug...
17 years agoI think Jake already proposed a solution there:
http://www.alteraforum.com/forum/showthread.php?t=6112 Quoting him: 1 - Manually specify the base address of your pipeline bridge to be 0x00000000. 2 - If# 1 doesn't work, manually set the base address of your pipeline bridges to match the base address of whichever component has the lowest base address on your tristate bridge. Does it work for you?
