16 years ago
SOPC builder ERROR: peripheral controlled wait ... What it means??
I add an user logic module with avalon-mm slave interface and conduit interface in the sopc builder and when "generat", it gives errror at end signed:
***:peripheral controlled wait not supported for peripheral with non-zero setup and /or hold times 255
I know this is caused by the "waitrequest" signal in the mm-slave interface which i used but what can i do with this??
the VHDL of the module like this(just used to transform the dataread and datawrite into a bir-direction dataRW):
___________________________________________
--This file is for avalon_MM slave interfacing test
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
--end of library decleration
entity No_clk_avalonMM_slave_adpter is
--entity name should be the same as the VHDL project name
port
CSn_from_MM: in std_logic:='Z';
RDn_from_MM: in std_logic:='Z';
WRn_from_MM: in std_logic:='Z';
dataW_from_MM: in std_logic_vector(15 downto 0):=(others=>'1');
dataR_to_MM: out std_logic_vector(15 downto 0):=(others=>'1');
ADDR_from_MM: in std_logic_vector(15 downto 0):=(others=>'Z');
ByteSL_from_MM: in std_logic_vector(1 downto 0):=(others=>'Z');
waitrequest_to_MM: out std_logic:='Z';
--CLK_from_MM: in std_logic:='0'; --avalon CLOCK
CSn_to_PHY: out std_logic:='1';
RDn_to_PHY: out std_logic:='1';
WRn_to_PHY: out std_logic:='1';
ADDR_to_PHY: out std_logic_vector(15 downto 0):=(others=>'Z');
ByteSL_to_PHY: out std_logic_vector(1 downto 0):=(others=>'Z');
BUSYn_from_PHY: in std_logic:='0';
DATA_fromto_PHY: inout std_logic_vector(15 downto 0):=(others=>'Z')
end No_clk_avalonMM_slave_adpter;
architecture slave2phy of No_clk_avalonMM_slave_adpter is
signal temp4MM_W: std_logic_vector(15 downto 0);
begin
CSn_to_PHY<=CSn_from_MM;
RDn_to_PHY<=RDn_from_MM;
WRn_to_PHY<=WRn_from_MM;
ADDR_to_PHY<=ADDR_from_MM;
ByteSL_to_PHY<=ByteSL_from_MM;
waitrequest_to_MM<=BUSYn_from_PHY;
process(WRn_from_MM,RDn_from_MM,DATA_fromto_PHY)
begin
if(CSn_from_MM='0')then
if(WRn_from_MM='0' and RDn_from_MM='1')then
DATA_fromto_PHY<=dataW_from_MM; --AVALON MM write data to the peripheral
dataR_to_MM<=(others=>'Z');
elsif (RDn_from_MM='0' and WRn_from_MM='1')then
DATA_fromto_PHY<=(others=>'Z'); --prevent the INOUT port datastream loop!!!!!
dataR_to_MM<=DATA_fromto_PHY; --AVALON MM read data from the peripheral
else
DATA_fromto_PHY<=(others=>'Z'); --uncertain status!
end if;
else
end if;
end process;
end slave2phy;
___________________________________________________
    --- Quote Start ---
    I don't think the trouble is in your HDL code. Is this a new component or are you trying to upgrade it from an existing component? The error would indicate that you've specified read and/or write wait times of something other than zero in the component wizard.
    --- Quote End ---
    Thanks!! the problem is solved, when i reanalyze the HDL file!!
    --- Quote Start ---
    --- Quote End ---
    Hello!
    Yes I made an update form this VHDL file, first there is no "waitrequest" and i define the read/write time in the SOPC builder, there is no erro. Then when i added the "wait" signal, the read/write definition window become gray(I can define nothing there). and then when I push generat, the error appear.
