16 years agoSOPC builder ERROR: peripheral controlled wait ... What it means??
I add an user logic module with avalon-mm slave interface and conduit interface in the sopc builder and when "generat", it gives errror at end signed: ***:peripheral controlled wait not supported ...
16 years ago --- Quote Start --- I don't think the trouble is in your HDL code. Is this a new component or are you trying to upgrade it from an existing component? The error would indicate that you've specified read and/or write wait times of something other than zero in the component wizard. --- Quote End --- Thanks!! the problem is solved, when i reanalyze the HDL file!!
