16 years agoSOPC and beginbursttransfer
I am creating a custom Avalon MM Master that will need to speak to a HPCII DDR2 controller. Rather than generating the core in the SOPC tool, we are generating it using the Megawizard in Quartus. ...
14 years agoI wrote the following and seems to be working so far.
-- This module:
-- * generates the beginbursttransfer signal, which is blatantly missing in qsys when exporting avalon-mm ports.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity beginburst_gen is
port (
rst : in std_logic;
clk : in std_logic;
burstcount : in std_logic_vector;
readreq : in std_logic;
writereq : in std_logic;
rdatavalid : in std_logic;
waitreq : in std_logic;
beginburst : out std_logic
end entity;
architecture rtl of beginburst_gen is
type state_t is (st_idle, st_wburst, st_rburstwait, st_rburst);
signal state : state_t;
signal bcnt : unsigned(burstcount'length-1 downto 0);
constant one_burstcount : std_logic_vector(burstcount'length-1 downto 0) := (0 => '1', others => '0');
begin
syn_proc : process(clk)
begin
if rising_edge(clk) then
if rst = '1' then
state <= st_idle;
else
case state is
when st_idle =>
if readreq = '1' then
bcnt <= unsigned(burstcount);
if waitreq = '0' then
state <= st_rburst;
else
state <= st_rburstwait;
end if;
elsif writereq = '1' then
if waitreq = '1' then
state <= st_wburst;
else
bcnt <= unsigned(burstcount)-1;
if burstcount /= one_burstcount then
state <= st_wburst;
end if;
end if;
end if;
when st_wburst =>
if writereq = '1' and waitreq = '0' then
bcnt <= bcnt-1;
if bcnt = 1 then
state <= st_idle;
end if;
end if;
when st_rburstwait =>
state <= st_rburst;
end if;
when st_rburst =>
if rdatavalid = '1' then
bcnt <= bcnt-1;
if bcnt = 1 then
state <= st_idle;
end if;
end if;
when others =>
state <= st_idle;
end case;
end if;
end if;
end process;
comb_proc : process(state, readreq, writereq)
begin
beginburst <= '0';
if (state = st_idle) and (readreq or writereq) = '1' then
beginburst <= '1';
end if;
end process;
end architecture;
