    --- Quote Start ---
    ok then, congratulations.
    about your next problem.
    I don't know where/when you meet this message.
    you should describe detail.
    --- Quote End ---
    In nios ii ide , when i try to run project
    Thanks , I solved this problem long ago , but now i have another. In IDE : image on board is newer than expected
    --- Quote Start ---
    hello
    the reason is that your memory is too small.
    you have just 20 byte on onchip_memory2_0.
    what a hell do you think you can do with it.
    --- Quote End ---
    I changed the memory settings , nothing has changed
    hello
