8 years agoSome questions about intel HLS RTL design.
Hello. I am currently testing RTL design using Intel HLS. There are a number of errors that occur during HLS compilation and RTL conversion, but the error seems to lack work around or guide...
8 years agoHi,
1. HLS generates handshaking logic to interface with the rest of your system. In addition to the parameters you specify, it generates a component invocation interface containing the start/busy and done/stall signals. 2. You can use the hls_always_run_component attribute to disable the handshaking logic (Can check in RTL viewer):
component float add_fp_tiger(float a, float b) {
float p;
p = a + b;
return p;
} // test the scalar addition within hard-FP Note that with the handshaking logic disabled, you cannot use the co-simulation flow to validate your component (like Xilinx). Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
