8 years ago
Some questions about intel HLS RTL design.
Hello.
I am currently testing RTL design using Intel HLS. There are a number of errors that occur during HLS compilation and RTL conversion, but the error seems to lack work around or guide.
I'd like to ask you a few questions about this difficulty. This includes questions about HLS optimization errors and their own concepts.
- Is the intel HLS software for creating one independent RTL IP?
- Does a verilog top design with multiple sub-modules(instances) need to be designed manually? (I don't need to use SOPC or SOC. So, I also don't consider Qsys to design)
- Is it possible to obtain a generic sequential RTL design with HLS that does not include an Avalon interface? What is the exact purpose of the hls_always_run_component?
- The user manual says that the HLS/matrix_mult.h library for matrix multiplication is provided, but where is it located? Not found in Quaruts 17.1 standard and lite in use.
- Where can I find the meaning of error messages generated when converting the FPGA?
I got an error : Call parameter type does not match function signature! What does this mean?
Here's a code structure I've created. Please give me a lot of advice.
code: main.cpp
float (*function1(x,x,x))[3] {}
float (*function2(x,x,x))[3] {}
float (*function3(x,x,x))[3] {}
component float (*aaa())[2] {
float (*y1)[3] = function1(x,x,x);
float (*y2)[3] = function1(y1,x,x);
return y9;
int main() {
float (*aaa_out)[2] = aaa();
printf("%f\n", aaa_out[0][0]);
return 0;
  • NSuku1's avatar
    NSuku1
    Hi!
    I am using Quartus Prime Standard 18.1. Still, I could not find the matrix_mult.h header file.
    Please let me know.
    Nivetha
    1. HLS generates handshaking logic to interface with the rest of your system. In addition to the parameters you specify, it generates a component invocation interface containing the start/busy and done/stall signals.
    2. You can use the hls_always_run_component attribute to disable the handshaking logic (Can check in RTL viewer):
    component float add_fp_tiger(float a, float b) {
        float p;
        p = a + b;
        return p;
    }  // test the scalar addition within hard-FP
    Note that with the handshaking logic disabled, you cannot use the co-simulation flow to validate your component (like Xilinx).
    Anand Raj Shankar
    Thank you very much. Excuse me, but I have one more question.
    When can I use hls_always_run_component option? What is happening If I use this option? User manual is not enough to understand for me.
    The error may be because:
    A component cannot include virtual functions, function pointers, or bit fields.
    --- Quote Start ---
    --- Quote End ---
    Yes you can create, check the 4.1.1 Scalar parameter of linkhttps://www.altera.com/en_us/pdfs/literature/hb/hls/mnl-hls-reference.pdf
    All pointers share a single Avalon Memory-Mapped (MM) master interface that the component uses to access system memory.
    --- Quote Start ---
    - The user manual says that the HLS/matrix_mult.h library for matrix multiplication is provided, but where is it located? Not found in Quartus 17.1 standard and lite in use.
    --- Quote End ---
    Check-in Quartus version 18.
    --- Quote Start ---
    --- Quote End ---
    Yes, Generates reusable intellectual property (IP) for system integration using the Platform Designer (formerly Qsys).
    Anand Raj Shankar
