12 years agoSome of my PWM signals fed into CPLD chip are MISSING?
Hello, I connected my TI DSP TMS320LF2810's PWM signals output pins to the pins in Bank3 of my CPLD chip EPM1270F256. There are overall 6 PWM signals from DSP to CPLD chip. However, ther...
12 years ago --- Quote Start --- Hi Kaz, Sorry, I don't quite get you. Do you mean that connect all 6 DSP PWM output pins to one known PWM output pin in the DSP? I am very sure the code is fine since I tried it in another version of my board in which I used the same DSP chip but without CPLD chip. The 6 PWM outputs are active from the DSP. Thanks! --- Quote End --- I suggested driving all 6 dsp output pins by one known pwm signal. But you seem to say that all 6 output pins are active without cpld so something went wrong with cpld connection. How do you observe the pins? could be they are accidentally connected to ground or Vcc
