open01's avatar
open01
5 years ago
Some issue with "ASMI IP parallel ip"
Hi ,
I am currently trying to use PCI-E to transfer data(8byte/once) and write the data to EPCQ through ASMI(page write), but unexpected phenomena appeared in the result, as shown in Fig.
Here is the data I transferred:
And when I use SignalTap to check the input waveform of "ASMI IP", the status is all good, as shown in Fig(The beginning data matches the data I transmitted, in order A1h, A2h, A3h, A4h, A5h, A6h, A7h, A8h):
But when I checked the data from EPCQ, I found that the data was wrong.
So why does SignalTap look good, but the result is wrong?
Does anyone have some ideas to share with me?
Thanks for your answers.
  • open01's avatar
    open01
    5 years ago
    Thanks for your response.
    Finally I know where the problem is.....
    Because when I use page write, I have to pay attention to the relevant regulations of start address as shown in user guide,
    Thanks again for your assistance.
  • YuanLi_S_Intel's avatar
    YuanLi_S_Intel
    Can you try to remove the sector before writing into it? Also, you might need to have some delay after executing write operation.
    Bruce
    • open01's avatar
      open01
