solaris install doesn't work right
i have the de1 board for a college course but i'm having trouble installing the software. i installed opensolaris since i usually use ubuntu which is not supported. no matter where i install it i keep getting a message like this.
[quote/Is there at least 6367984 kbytes available in /altera (type n to stop this installation)? (y/n): y /media/ALTERA_SOFTWARE/tools/solaris/compare: Invalid argument ------------------------------------------------------------ You do not have enough disk space to install the requested items. There are only 6367984 kbytes in /altera. --- Quote End --- i have plenty of hd space but it's just not installing. i don't know what to do.4 Replies
Does the Ubuntu installation instructions work for Solaris too? Wonder why they drop support for Solaris? OpenSolaris is open source anyway...
You must have an old version of Quartus then, because support for Solaris has been dropped since 8.0 I think.
You can try and follow this guide (http://www.nioswiki.com/@api/deki/files/43/=altera_software_installation_tutorial_for_ubuntu.pdf). According to it, you must ensure that you have tcsh installed and not csh. It could be the cause... - Altera_Forum
but it says tight on the box that it supports solaris. it even asks you if you're installing it to solaris or linux in the installer! i also tried it in ubuntu but i got the same problem
Solaris isn't supported. The only unix-like OS supported are Linux distributions: Red HaT Enterprise, SUSE Enterprise and Cent OS.
You can install it on Ubuntu or any other linux distribution though, even if it's not supported.
