iDirect_Martin's avatar
iDirect_Martin
4 years ago
Software header files for non sopc_builder component ip
Are header files available for intel ip like jesd204c or e-tile registers?
  • Martin,
    The reference I pointed was for generate .header for component that associated with platform designer. Otherwise, you have to manually created it. Let me know any concern on this.
  • SyafieqS's avatar
    SyafieqS
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
  • SyafieqS's avatar
    SyafieqS
    Martin,
  • SyafieqS's avatar
    SyafieqS
    We do not receive any response from you to the previous reply that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
    • iDirect_Martin's avatar
      iDirect_Martin
      This appears to be used to generate a system-level header file like system.h for Nios-based designs. It does not provide the definitions of every register and bit field in a device. Plus our design is not entirely created in Platform Designer.
      I guess we'll have to manually create those files.
  • SyafieqS's avatar
    SyafieqS
    Martin,
    Understood, I am not SOC expert, let me check this internally and get back to you with findings.
  • What I mean is a header file that lists register and bit field information similar to altera_avalon_pio_regs.h.
    I have the jesd204c ip instantiated and connected to the HPS in Agilex. I do not connect this to Nios.
  • SyafieqS's avatar
    SyafieqS
    Hi Martin,
    Assuming I understand the question, If you are using nios processor and jesd204c in platform designer for hardware design, Quartus will automatically generated the header file of the whole system including the ip jesd204c itself
